PXI
DAQ TB-2708 Sampling Rate and DAC Resolution Bit
I would like to know where can I find the sampling rate and DAC resolution bits of DAQ TB-2708.  I looked at the datasheet(attached) but I did not get the information from that.  Thanks!
(2,761 Views)
Accepted by topic author J999000
That is just a a terminal block.  What DAQ is connected to?  The DAQ is what does the sampling.
GCentral
(2,745 Views)
The DAQ we connected is NI 6115.  It has 12 bits ADC resolution and 10MS/s maximum sampling rate.  So the function of TB-2708 is just to receive the analog signal?  Thanks!
(2,737 Views)
More like it just makes it easier to connect your signals to your DAQ.
GCentral
(2,724 Views)
