PXI
DAQMX Task change position of channel to enable/disable position without distrupt other channels
Hello, I'm trying to use PXIe-6738 device. During last 2 days, i'm trying to find a way to change position of channel to enable/disable position without distrupt other channels. Stopping a task makes signal interrupt and i can't do that. Should i use relay for this?
Message 1 of 1
(2,235 Views)
