PXI
DStar does not work
My setup is:
- PXIe-1082 chasis
- PXIe-7962R FlexRIO
- custom MRF timing card
I want to send data via the DStarB line from the custom FPGA to the FlexRIO. I am reading the DStarB line in my LV FPGA program.
The problem I have is that I only get the data when the DStarB line goes from '0' to '1'. If I send two '1' after another I only get the first one, because I only recognize the positive front. I would wager that the backplane has a setting for this DStar lines. Some pull-downs or something...
Do I need to enable something in the chassis settings in NI MAX? I went over everything but cannot find something useful.
Do I need to configure the backplane with my timing card somehow?
I am running out of ideas, so please do help.
(3,321 Views)
I did a bit of digging. I cannot read the VI_ATTR_PXI_DSTAR_BUS and VI_ATTR_PXI_DSTAR_BUS_SET attributes of the PXIe-7962 card from the LabVIEW program. The attributes are also not present in the VISA Interactive control Attributes list.
Is there a problem, because the crate is not configured to work with my custom timing card?
Or is the problem in the FlexRIO configuration?
(3,287 Views)
