PXI
Daqmx
I am writeing a program which is very large and am struggling. What happens if you set up a state maching and start and stop Daqmx tasks. Do you miss data?
I am writing a program which collects data for 4 actuators ( motor , Brake, Encoder) I am collecting 9 points on each actuator.  I am very confussed. If I create a task out side the loop so I don't start and stop the task I can't do more than one set of data. I get errors that basically say I have a task using the same resource. If I put it all into one task thats no different then the Daq assitant.
I have to believe this is something others have done. What am I doing wrong? what am I missing?
Scott
(3,462 Views)
Hi Scott,
I'm assuming that you are doing an analog input acquisition on each of those actuators.  On the E-Series and M-Series data acquisition boards, only one analog input and one analog output task can be run at any given time.  There is a KnowledgeBase article here that refers to the error you are receiving with some suggestions on how to modify your code.
Andrew W
(3,452 Views)
Thanks Andrew
(3,439 Views)
