PXI
Deployment error 307703
Hola estoy intentando introducir un modelo compilado con labview en Veristand, pero me sale el error 307703 cuando le doy a deploy. Me aparece este error.
Deployment Error
Project Window.IvIib:Praject Window.vi > > Project Window.IvIib:Command
Laap.vi > > Project Window.IvIib:Cannect ta System.vi
append
NI VeriStand: NI VeriStand Engine.IvIib:VeriStand Engine Wrapper (RT).vi > >
NI VeriStand Engine.IvIib:VeriStand Engine.vi > > NI VeriStand
Engine.IvIib:VeriStand Engine State Machine.vi > > Model
Execution.lvlib:lnitialize Model Loop Data.vi >> Model
Execution.lvlib:lnitlalize Models.vi > > SIT Model API .lvlib:lnitialize Model.vi
append
NI VeriStand: Initialization error code 7
Errar -307703 occurred at Project Window.IvIib:Project Window.vi > >
Project Window.IvIib:Command Loop.vi > > Project Window.IvIib:Connect
to System.vi
NI VeriStand: The specified model is incompatible with VeriStand ar the
current deplayment target. This can accur if the model does nat match the
operating system yau are deplaying ta, such as using a Windows model far
an NI Linux Real-Tlme target.
NI VeriStand: NI VeriStand Engine.IvIib:VeriStand Engine Wrapper (RTJ.vi > >
Executian.lvlib:lnitialize Model Loop Data.vi Model
Executian.lvlib:lnitlalize Models.vi > > SIT Model API .lvlib:lnitialize Model.vi
append
Alguien sabe porque podría ser?
(506 Views)
@Aaron-Ingeteam wrote:
Hi, I'm trying to introduce a compiled model with Labview in Veristand, but I get error 307703 when I click deploy. I get this error.
Deployment Error
append
append
to System.vi
append
Does anyone know why this could be?
What is your VeriStand and LabVIEW version?
Which target are you deploying to? Windows, Pharlap, Linux?
What is the extension of the model generated? DLL or SO?
https://tmesystems.net/
(480 Views)
I will try to answer you.
What is your VeriStand and LabVIEW version? both 2024 Q3
Which target are you deploying to? Windows, Pharlap, Linux?Linux
What is the extension of the model generated? DLL or SO? SO
(455 Views)
