PXI
Determining "Device Name (Slot Number)" of 6070e in RT for AI Config
I am trying to start data acquisition using a 6070e card on my PXI chassis using AI Config.  But the AI Config node requires a device name.  In Labview 7.1 (non-RT), the deivce name was just the slot number 3.  I searched MAX and the new device number in RT mode is device 15.  But it doesn't acknowledge this number.  Does this not work in RT as it does in Windows?  Any suggestions?
Jessica A.
(3,040 Views)
is your card in a chassis with RT controller??
If it is, in max, go to menu tools>>traditional DAQ configuration>> remote DAQ configuration>>enter your RT controller's IP number to access that RT system.Here, you will find the device number of your PXI6070E card.
use this device number in AI config function
regards
Dev
Message Edited by devchander on 04-20-2006 07:09 AM
(3,033 Views)
