PXI
Difference between ADC resolution and measurement resolution
What is the difference between the ADC resolution and the Measurement resolution? Is the measurement resolution the same as the effective number of bits? How can the measurement resolution be higher than the ADC resolution?
Source: PXIe-4309 Specifications
(1,154 Views)
Measurement resolution is the realistic resolution you can get from the instrument as a whole.
Santhosh
Soliton Technologies
(1,123 Views)
It seems but it's still pretty unclear. If you go see the graphs, the lowest resolution is still under 18 bits...
(1,082 Views)
