04-06-2009 03:50 PM
Hello --
I am have a PXI Pickering 40-540-021 Matrix card. Ultimately I want to define routes for this card in NI Switch Executive, but so far I haven't been able to recognize the card in MAX. A little more info....
I've installed the VISA and IVI drivers for the card from PIckering, and it shows up fine under the Windows Device Manager. But when I expand the PXI System node in MAX (under Device and Interfaces), the slot housing the Pickering card shows up as being empty. I have some National Instruments PXI devices in other slots, and they DO show up correctly in the PXI System in MAX.
My questions:
#1) Am I correct that the card needs to show up here in MAX before I can set up an IVI driver session for it?
#2) If the card does need to appear here before I can continue, what can I do to see it there?
Any suggestions would be much appreciated!
Bryan
04-07-2009 10:38 AM
Bryan,
In MAX, try going to Tools»NI-VISA»VISA Options, then go to General Settings under My System. Choose the option under PXI/PCI and Firewire Interfaces to Show all devices accessible to VISA.
Next, follow the instructions in the DevZone tutorial, Using Measurement & Automation Explorer 3.0 to Configure Your IVI System. This tutorial is targeted at MAX 3.0, not 4.5, but the process is similar.
Ben
