PXI
Digitizer Self calibration error
Hi Everybody,
I am using NI PXIe- 1075. contain 5 RFSA. Between time to time I get the  (-200221) which says the Maximum time exceeded  out befor the operation complet . I asked before and advised to use the self calibration. I have five digitizers, I could do self calibration to 4 of them but the fifth one I couldn't do the self calibration for it. I have read a document says there is another soulution by using the property node as shown in the attached picture. but I don't know how to use it. could any of you please help me to explain to me how to use this property node. or have another Idea to solve the problem.
thank you in advance for your attention
best regards
Thoalfukar
(4,119 Views)
Just follwing to the post above. this is the error message when I do the self calibration. Please see the attached picture
(4,115 Views)
Hi! Are you referencing this article? How are you having trouble using it? It appears like you would just drop the property node in your block diagram, and set the property to "Incomplete."
It sounds like you may need to have your module sent in to NI for repair. I would recommend calling the support team, and asking to initialize an RMA through them.
(4,101 Views)
Thanks for your attention
I already contacted the NI and trying to solve the problem without send it.
Thank you again
(4,092 Views)
