PXI
Diskless Pharlap using PXE on PXI
Dear Labview users,
How can I boot a PXI without harddisk using Pharlap (LabviewRT)?
I can boot the PXI without harddisk on DOS, Linux and Windows PE using a DHCP server and a TFTP server (using PXE).
I've made an image of the PXI harddisk to start it from the RAM (using PXELinux and memdisk, http://syslinux.zytor.com). The RT engine begins to boot but hangs because Pharlap OS  try to read on the harddisk.
Is-it possible to make a diskless PXI running Pharlap?
Thanks.
(3,432 Views)
Hi Mathieu,
No, you cannot make a diskless PXI running Pharlap.
Why are you trying to do this?
Michael K. | Applications Engineering | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,418 Views)
