PXI
Display syncronization
I'm having a problem in displaying results. I'm using Labview FPGA and i want to pass data from target to host program, then display the results on a waveform chart. The program works fine on simulation, once it is compiled on target i lose syncronization between pollted results. how this can be solved?
(6,087 Views)
it can probably be solved fairly easily
Stu
(6,076 Views)
Any suggestions about any of these ways?
(6,065 Views)
do you try FIFO for data transfer between FPGA and host. are you  sampling analog signal and displayed it on host (pc) . can you share snapshot of your fpga and host vi ?
(6,050 Views)
I'm already using FIFOs between target and host and it is working fine on simulation. Once compiled an run the bit file i lose syncronization.
I'll try to get snapshots when i reach my office.
(6,040 Views)
what are the signs of losing synchronization. did you miss the data in diaply you measured via fpga or some thing else
(6,037 Views)
