PXI
Documents on NI DC Power Supply
Can somebody point me to the document that has detailed function and it's generated signals for PXI DC Power?
My PXI system has PXI-2535 switch matrix and PXIe-4141 SMUs:
I am reading example: NI-DCPower Sequence Multi-Channel Sync
For the following code, the comment says it will Export source trigger after device starts sourcing. I have "NI DC Power Supplies and SMUs Help" after driver is installed. I went on to search niDCPower_DisableSourceTrigger(). The document explains the function formats, parameters, and return value. But it doesn't mention which signal/attributes it generates. So how do I know which signal/attributes it generates?
 /* Configure the Source trigger. On the master device, the Source
trigger is disabled (None). This means that the device will source
without waiting for a trigger. When the device starts sourcing, it
will export the Source trigger. */
checkWarn(niDCPower_DisableSourceTrigger(vi));
Yimin
Message 1 of 1
(938 Views)
