PXI
Does any NI modules do audio analysis and Audio signal generation
We are looking at a PXI based test system to do receiver testing and we need modules to do audio analyis and audio signal generation.
We need to do sinad measurement also.
We need PXI based oscillocope and a DMM
We need Pxi based RF signal generator and a Digitizer
Suggest necessary modules
(2,965 Views)
Hi Anil,
I assume that you will be generating and receiving a modulated signal.  What will be the carrier frequency of this generated signal?
Here's some suggestions that I have for the RF signal generation and acquisition portion of your application:
PXI-5671 Vector Signal Generator
PXI-5661 Vector Signal Analyzer
Please provide more specifics on your application.  What voltage ranges will you be measuring with the DMM?  In general, what frequency ranges will you be generating and analyzing?
Andrew W
(2,954 Views)
