PXI
Driver for DALSA Camera
I have a Dalsa S-12-16K5H camera that I am trying to drive with the IMAQ PXI-1422 board.
I am connecting the camera through SCB 100 breakout box and further connecting it to PXI-1422 board.
1. I would like to know what is the most appropriate driver that could be used for the camera for interaction between the camera and the LabView software.
2. I would be performing higher rate image acquisition - what would be the pinouts when connecting to the SCB 100 box and the camera
(1,322 Views)
Hello!
The driver can be found here- you will just need to select the version for your operating system.
The pinout for the device can be found in the manual here.
Hope this is helpful!
(1,252 Views)
Thank you, Apex_Waves
(1,232 Views)
