PXI
Dual Boot PXIe-8840 with installed Windows 10
I am completely new in the issue of OS PXI. I have PXIe-8840 with installed Windows 10. I need to install an RT OS. I would like to switch between WIN OS and RT OS as described here . However, I have found a NI web page where it is not recommended or said to be impossible.
Is there any other way how to have dual boot on my PXI ?
(1,174 Views)
Hello charlie87,
I would like to inform you that you can solve it in this way only:
  • Install Windows 10 by the MBR partition.* But keep in mind that, is not recommended by NI. NI is not responsible for any malfunctions of the PXIe controller.
  • In otherwise, you should use a second SSD/HDD by changing it in order.
* In my personal experience, it should work without any problem.
Best Regards.
(1,113 Views)
