PXI
Electrical Measurements
what is the Maximum Power, voltage,current a Pxi system can Measure in a Substation ???
(2,561 Views)
That entirely depends on the cards you put into the PXI system.  What are you trying to measure?  How many channels do you need?
GCentral
(2,551 Views)
In Power system Lab voltages are measured upto 22KV ,is it possible to measure the same using a PXi?? if yes, can you please let me know the Pxi & cards that can be used to measure the same
(2,539 Views)
