PXI
Emulating a SCXI-1162 with a PXI6529
I have a system that uses the SCXI-1162 HV inputs to detect 110 VAC inputs from multiple sources only to detect On or OFF.  Since the 1162 is no longer available I chose the PXI-6529.   The 6529 doesn't have the input range of the 1162 and I am wanting to know if anyone has run into a similar situation.  I only want to detect Hi/Lo from a 110VAC signal.
Message 1 of 1
(2,108 Views)
