PXI
Error 1074097771
I'm trying to run self calibration on PXIe 5820 (Vector signal transceiver) using RFmx soft panel, but it throws the below error.
self calibration failed.
NationalInstruments.RFmx.InstrMX: -1074097771: Error description not found.
Error code: -1074097771
also the Q IN channel shows a degraded signal than the actual input
say if input is 1Vpp, Q IN channel in RFSA shows 0.8Vpp.
Message 1 of 1
(587 Views)
