PXI
Error -1074117754 thrown when sequence tries to initialize PXI-4070
My customer is reporting that when TestStand attempts to initialize hardware at the start of the product test sequences, the system throws an error -1074117754.  He believes that it's associated with the PXI-4070 DMM, as he also cannot talk to the card with the soft front panel.  Has anyone seen this code before?  Any ideas what it means?  Any known fixes?  Thanks!
(3,345 Views)
Issues concerning this error have typically indicated faulty hardware in the past, so you may have to RMA it.  However, before you try that, try the following troubleshooting steps:
- Reboot
- Re-install DMM drivers (make sure to use the newest version: 2.6)
- Try the card in a different PXI slot
- Try the card in a different PXI chassis
- Try a different DMM in the same PXI chassis and see if it works
Again, we've seen this issue before, so if it persists, contact support so you can send it in for repair.
Elijah Kerry
NI Director, Software Community
(3,334 Views)
Thanks, Elijah, I'll pass that along to my customer.
(3,321 Views)
