PXI
Error -201342 "Unsupported Accessory" when using MAX to create tasks PXIe-4330 & TB-4330.
Hi all!
I have an -18 slot PXI chassis with multiple PXIe-4330 and TB-4330 installed.   When attaching any TB-4330 to the -4330 module within slot 11 and generating a task within MAX, the system returns the following error: "-201342, unsupported accessory". Any task can read all other slots without generating an error.
I don't expect this to be SN based as the TB is interchangable with -4330s in other slots though MAX will not allow me to add a TB-4330 to the configuration.
How can i help MAX see the TB-4330 within slot 11?  Is there a driver update that corrects this?
Thank you!
(5,255 Views)
Hi Mlvca,
Our support team is currently working on this issue. If there are any other suggestions, please feel free to post.
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(5,234 Views)
Did you find the reason why the terminal TB NI 4330 is presented to MAX as 'unsupported accesorry'?
(3,005 Views)
I was unable to find further information on this device showing as unsupported.
Since this post is older, please create a new post with your question in the forum. This will allow our R&D team to track the issue for future potential fixes.
Anthony
Anthony M.
Applications Engineering
(2,995 Views)
