PXI
Error during software installation
HI,
     I have PXI 8106 with real time software. I'm trying to iinstall labview runtime engine 11.0 and veristand run time engine 11.0, But i'm getting after installation from MAX. After installation of the software it gives NI variable engine: ERROR: Unable to load the MXS configuaration plugin.
Please do tell me how remove this error?
Message 1 of 9
(6,435 Views)
Hi jay,
have you installed the real time operating system once again?
In my opinion it´s the best to solve those kind of problem.
Greetings
Message 2 of 9
(6,422 Views)
     No i have not installed the real time OS. How to re-install the real time os?
Message 3 of 9
(6,415 Views)
Hi Jay!
First: Format your Real-Time PXI
How Do I Format my Real-Time PC or Real-Time PXI Target to the Reliance File System?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LpRSAU&l=en-US
Secondly: Install the required software and drivers
Installing Software on your Real-Time (RT) PXI Controller
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILGCA4&l=en-US
or
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x38BCAQ&l=en-US
Much success!!!
Message 4 of 9
(6,376 Views)
       Thanks a lot formating and reinstalling worked, but there's another problem now. I'm not able to see the NI veristand real time engine 11.0 running. But i have installed the software with Labview real time 11.0.
 Please do help if any suggestions.
Message 5 of 9
(6,373 Views)
first install Veristand on your host, after that deploy the real-time engine to your target.
Getting Started With NI VeriStand
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGCBCA4&l=en-US
Message 6 of 9
(6,363 Views)
HI,
      I have done like that only. But it doesn't seeems to appear on the console.
Message 7 of 9
(6,361 Views)
please send me a Max-Report from your system?
Documenting Measurement & Automation Explorer (MAX) Configuration Information Through MAX Technical Report
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q0000019hceCAA&l=en-US
Make a screenshot of the Software which is available to install on your target. (see attachment)
Message 8 of 9
(6,345 Views)
could you solve the problem?
Message 9 of 9
(6,329 Views)
