PXI
Error in reading voltage using DAQmx with PXI-6259
We are trying to acquire analogue voltage from 5 channels using PXI-6259. We trigger the data sampling with clk 0 (i.e. using PFI 12).
The problem we had is:
1)When we tried to get voltage from 5 channels, we get 2 data at the same after twice the period. For example, If we set the
  sampling rate to be of period 1 second, we get 1 signal at 2 second and around (2+t), where t is a random time less than the execution period of the loop.
  Then the next cycles would be 4 second and (4+t).
2) This timing problem did not occur if we only acquire voltage from 2 or less channels.
3) We tried to run exactly the same program with NI USB-6210 and everything worked just fine.
4) We replaced the DAQmx read with DAQ assistant and still encountered the same problem.
Attached is the a simple program that showed the error. Is this possibly a bug in PXI or DAQmx?
Please help us
Arul (CLAD)
Message 1 of 1
(4,201 Views)
