PXI
Ether Unidentified
Hello, I have a PXI 8110 all hooked up, it started up normally, however when I connect the Ethernet to my computer, the hardware is unidentified.
What do I need to adjust?
Thank You,
(2,832 Views)
This controller is meant as a standalone computer and doesn't need a host computer to configure or run it.
All interfacing with the device will be through the PXI platform services driver , so make sure this is installed on any PC that interfaces with it.
PXI 8110 User Manual
Matthew C
AE | NI
(2,798 Views)
Hello Matt C,
Thank You for the help, but PXI platform services driver already installed.
(2,790 Views)
