PXI
Ethernet Packet Detection Settings
I am using the
PXI-1031 Chassis
PXI-8106 Embedded Controller
The goal is the run the Benchmarking program and one of the notes say to set the ethernet driver to polling.  However when I open MAX and go to the PXI Image to the Advanced Etherenet Settings, I see the Packet Detection option, however, the polling option is grayed out.
Thank you all for you help!
-Kevin
(3,597 Views)
Could you give us a bit more information?  Are you opening MAX on the embedded controller, or is it running the real-time operating system?  Also, can you provide a link to this document you're referring to?  Thanks!
Chad B. » National Instruments » ni.com
(3,584 Views)
Sorry.  We are using Real Time and the source is http://zone.ni.com/devzone/cda/tut/p/id/5423.  For the polling mode.
-Kevin
(3,580 Views)
Hello Kevin,
Is the card's mode set to TCP/IP Network?  If Help is selected in Advanced Ethernet Settings, notice that the option will be disabled if the mode is not set to TCP/IP Network.  Are you connected through a network or straight to a computer with a crossover cable?
Clint M
(3,556 Views)
