PXI
Ethernet Unix control for PIX system
I am looking into assisting to install a PIX rack with several power supplies into an existing test system running Unix.  Has anyone on the forum had any experience with interfacting PIX with an older Unix system and, if so, what was your approach in terms of both the hardware used and the code you wrote?  At this point I am looking at an Ethernet based solution as the Unix system has this currently and it - at least for right now - seems to be the most logical approach to take on the project.
Any thoughts, pointers, direction or general warnings are appreciated.
Andy Linnenkohl
(2,999 Views)
Make all of the above PIX PXI.
(2,995 Views)
