PXI
Example Code for PXI 6052E
I want to use a PXI 6052E to measure (time domain) analog signals passed by an SCXI module. I would really appreciate it, if someone could direct me to a code that would do something similar to my intended application. Thank you.
(4,085 Views)
Hello;
If you are using Labview to program the board, you can go to Search Examples->I/O Insterfaces->Data Acquisition->SCXI; and choose the SCXI module of yours.
If you are using another programming language than Labview and need to make NI-DAQ function calls; you can go to C:\Program Files\National Instruments\NI-DAQ\Examples\YOUR PROGRAMMING LANGUAGE\Scxi (where YOUR PROGRAMMING LANGUAGE is the language you are using).
Hope this helps.
Filipe
(4,085 Views)
