PXI
Execution targets
I have a vi that displays an image via a CCD and IMAQ card, and to use this vi I target my PXI box via its IP address. I have a second vi that outputs a signal via my FPGA card, and to use this I target the FPGA emulator. What I need is to have the FPGA output AND the IMAQ streaming image onscreen at the same time, but I don't know how to do this as it requires me to target two different things. How do I do it?
Cheers,
Rob.
(3,251 Views)
Rob,
I dont know if the following idea will work but you can give it a shot. If you have two versions of labview on the machine, maybe you can use one to target the FPGA and the other to target the PXI.
Prakash K
(3,236 Views)
