PXI
FIDL tools with NI 658*?
Can I use NI FlexRIO Development Tools with modules NI 6585 or NI 6587?
(4,116 Views)
There are now generic IDLs installed with the FlexRIO driver. If you have the FlexRIO driver installed, you should be able to check out this folder (C:\Program Files (x86)\National Instruments\LabVIEW 2014\instr.lib\_niInstr) and find a bunch of IDL folder libraries. The one you found a link to is older and intended for use with the digitizer adapter modules. Strictly speaking, there are no hardware limitations, but there are some functions meant for specific adapter modules that will not be applicable or make sense with your hardware.
(4,085 Views)
