PXI
FPGA 64-bit compilation for PXI-7842R board
Does anyone know if FPGA 23.1.0 (2023) 64-bit or later versions will support compilation on the PXI-7842R board?
FPGA Target Support for the LabVIEW FPGA Module 64-bit - NI
Gave me hope it would on the PXIe variant, but then I spotted "(Except the PXIe 7841/2R)". My project opened in 2023 Q3 (64) with FPGA 23.1.0 is showing the warning that the FPGA module doesn't support the current target.
Has anyone experience of compiling on the 32-bit version then running from LabVIEW using the 64 bit toolkit as the KB suggests? Any caveats?
Mark
Certified LabVIEW Architect
(467 Views)
I was able to add PXI-7842 and PCIe-7842 to a LabVIEW 2023 32-bit but not 64-bit.  There are several targets that are not supported in 64-bit.
I could not see a PXIe-7842; does this even exist?  I think the article may be incorrect; I will send feedback.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(447 Views)
Hi Terry,
Thanks for taking the time to investigate. We’ve actually decided to use a different R series board which is supported under 64-bit, so easy fix.
Cheers,
Mark
(420 Views)
