PXI
FPGA clocks
My specifications are:
- PXIe-1082 chasis
- PXIe-7962R FlexRIO
- custom MRF timing card
The MRF is pushing its clock to the PXI_CLK10_IN with own 10 MHz clock.
I am using multiple SCTL on the FlexRIO board with multiple clock sources. The availiable clock sources are (also look at the attachement):
- 40 MHz Onboard Clock
- PXI CLK10
- 100 MHz clock
- 200 MHz clock
- DStarA clock
I cannot get hold of the information what are the clock sources for 100 MHz and 200 MHz clocks. Are that special oscillators on the board? Are the clocks PLL-ed 40 MHz clock or PLL-ed PXI CLK10?
(3,756 Views)
Accepted by topic author leon43
(3,693 Views)
