PXI
GPS AND IEEE 1588
Greetings to everybody, I am new here, so please excuse if the question have been posted many times earlier. I tried to search, but couldn't find anything useful in short, so I choosed to ask here. I am using a PXI 6682H board with GPS and IEEE 1588 support (but should apply to the PCI version, too). I am using NI-Sync version 3.2.2. I would like to synchronize the PXI-6682 board to a GPS and output its internal PPS via PTPv2 protocol (IEEE 1588-2008) on the net. Would it be simpler to do it in CVI or LabView? Is there any reference design/example on how to do such a simple task? Or at least a skeleton? I couldn't find any example for IEEE 1588 in CVI and found only one in LabView but I don't know how to edit it.. Never used LabView before. I just need a few advices on how to start programming the board. Many thanks and best regards.
(4,411 Views)
Ok. I could manage to do something by calling VIs "Set Time Reference" and then "Start 1588 and Wait for Quality". I'll dig a bit more to do the same in CVI. What would you suggest? Many thanks. Giulio
(4,409 Views)
Hey Giulio,
Thank you for posting your needs on this forum. You are looking for a working system/architecture though, so it's difficult to clearly point you to a good solution. Anyway I would prefer to start by suggesting a couple of good articles/example I wish might help you. If you got this links yet, keep me updated and I will provide for additional information:
GPS Synchronization Architecture for Data Acquisition Devices
GPS Synchronization Architecture for DSA Devices
Return GPS Time Using NI-Sync and LabWindows/CVI
GPS Synchronization of DAQ Devices
Reference Design for Synchronizing DSA Devices using GPS
Let me know if you are interested in one of the previous.
Have a good day!
Best regards
Matteo
(4,327 Views)
Ciao Matteo. Many thanks for the links. I had already looked at some of them (but did not specified it earlier.., sorry) I will use some time to go through them and follow the learning curve. Anyway I was able to do everything I needed at first with the examples provided with LabView. I'll maybe try to replicate in CVI, just because I am more familiar with plain code than with block diagram.. But there is no hurry. Thanks for the info. Best regards Giulio
(4,321 Views)
