PXI
GPS sim. with PXI-5671
Hi.
It is possible to create a GPS tester in LabVIEW with PXI-5671?
Is GPS toolkit compatible with PXI-5671?
I have GPS examples compatible only with 6682.
Can you send me some gps example compatible with 5671?
Message 1 of 12
(7,598 Views)
I found this
http://www.ni.com/white-paper/7189/en
PXI-5672 can create a GPS signal..
Some GPS example? I'm novice in LabView.
Message 2 of 12
(7,582 Views)
Greetings,
The 5671 and GPS Toolkit are compatible with each other as per the GPS Toolkit datasheet.
http://www.ni.com/pdf/products/us/cat_gpstollkit.pdf
Examples will install with the Toolkit.
Product Support Engineer
Message 3 of 12
(7,571 Views)
I install GPS toolkit v2.0 and I don't see examples. (write vaweform to file and streaming from file)
Message 4 of 12
(7,550 Views)
On page http://www.ni.com/white-paper/7189/en
is write
You can use an example program, “niGPS Write Waveform To File,” to create GPS baseband waveforms (automatic mode)....
The GPS Simulation Toolkit includes example programs for both single-satellite and multiple-satellite simulations...
The specific technologies that enable streaming are not discussed here, but you can find more information and example code at ni.com/streaming/rf. In the following sections, explore how to configure an appropriate RF front end for an RF record and playback system...
So. I doesn't have any niGPS example on my pc (evulation copy) and PXI-1042Q (full version) in Labolatory. GPS toolkit on PXI install PhD., not me.
On the website is only record and playback sample.
GPS toolkit is this one http://joule.ni.com/nidu/cds/view/p/id/2287/lang/cs
Please help me, I need these examples.
Message 5 of 12
(7,539 Views)
Hi lacika,
Where are you looking for these examples? I don't believe they will be in the NI Example Finder. Instead, if you navigate to your start program -> All Programs -> National Instruments -> NI GPS Simulation Toolkit -> Examples, all the examples are located here. You can also navigate through your windows explorer to C:\Program Files\National Instruments\LabVIEW 2012\examples\RF Toolkits\GPS\Programming.
Josh Y.
Message 6 of 12
(7,530 Views)
I generate Mt Everest.bin -OK
But, when i can streming from file, labview pop up this error message.
http://sdrv.ms/VkuUiE
What now? i decrease  number of frames and update interval, and its still out of memory.
Message 7 of 12
(7,387 Views)
Hi Lacika,
Are using the example niGPS Streaming From File.vi, or a different example?  If you are not streaming from file and your waveform is larger than the onboard memory of the device, you will receive this error.
Brian G.
Message 8 of 12
(7,369 Views)
Yes, I use niGPS Streaming From File (5671).vi
I change Waveform Transfer Size. It works, but i dont know if correctly.
I find satellites for few tents of seconds in 3 min. waveform.
Message 9 of 12
(7,362 Views)
Hi lacika,
Does the program continue to run during the duration of the 3 minute waveform?  What are you using to receive the GPS signal?  Where in the 3 minute waveform do you recognize the signal, is it only at the very beginning?
Brian G.
Message 10 of 12
(7,339 Views)
