PXI
Generate TTL pulse using BNC 2121 with Labview 6.1
I need some help regarding Labview to generate TTL pulse. Just to let you know what i am using;
1.) LabVIEW 6.1 (which is older and i cant upgrade it, as it will lead to complication to the existing system and will take time)
2.) BNC 2121 with PXI-6602
3.) NI-DAQmx
Well, using this I want to generate a TTL pulse [it should be ON for specified time (say 10ms) and OFF for specified time (say 50ms)]. This pulse will be given input to one nor-gate IC (TC74HC02AP NOR Gate DIC), which will inturn turn on-off for the specified time.
Message 1 of 1
(4,495 Views)
