PXI
Generate continuous wave
I am working on a project which requires to generate a continuous single tone wave, calculate the signal length (or total duration in time domain) and then keep repeating the signal like a constant moving wave. I looked in to RFSG Single Tone Generation vi to check the output and found that the signal generated is continuous but not a continuously moving wave.
Could someone please tell me how to proceed after the RFSG generates the signal?
Thanks so much,
Sharmi
(4,794 Views)
Hi Sharmi,
The question is not clear to me, by saying that you need a continuously moving tone do you mean you want to change the frequency of the signal? If that is the case, you can have a look at "RFSG Frequency Sweep.vi". You can find the same in NI Example Finder at Hardware Input And Output>Modular Instruments> NI-RFSG> Sweeps.
Hope this helps.
Hardik Asawa
(4,786 Views)
