PXI
Getting Error -88302 when using PXI-4110 on PXI-1033
I kept getting error -88302 either doing self-test or opening DC power soft front panel. Other devices on my PXI-1033 work fine and the PXI-4110 works well when connecting with another computer. Is there any idea about what's going wrong? Tkx!
The error message looks like this:
Error -1074106671 occurred at niDCPower Initialize With Channels.vi
Possible reason(s):
An internal error occurred.
Status Code: -88302
(3,870 Views)
Hi dodderob,
Can you try to remove all other cards from the cahssis except for the 4110?  Also, do you have any exclamation points in the Windows Device Manager?  If yes, do you have an error code wtih the device?  Also, what version of DC Power do you have installed (this can be found in the software tab of MAX)?
Best,
Adam
Academic Product Manager
National Intruments
(3,857 Views)
