PXI
Getting no signal from PXI-4472b
My system includes PXI-1000b Chassis with PXI-4472B module and PCI-MXI-3. MAX recognises all hardware.I have configured ICP accelerometers as per specifications but i am not recieving a signal during tests through MAX. There are no error codes displayed.
(3,193 Views)
I would suggest sending a function generator signal to the board to see if you can get any signal to read. Even a DC signal would at least verify that the board is working correctly. Remember to enable AC coupling, to get rid of any DC offset created with the excitation.
(3,193 Views)
