PXI
Getting "Error 10 occurred" when building exe
I am getting the following error when trying to build an executable: "Error 10 occurred at C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Daq\lvdaq.dll"
Listed under possible reasons were:
LabVIEW: Duplicate path.
NI-488: New I/O attempted with old I/O in progress.
I made some changes and added a .vi to my program, but get no errors if I run the program from the top level .vi.
Any ideas?
(3,117 Views)
Hi Rob,
For some reason there's an issue with the link to the lvdaq.dll in your application. The lvdaq.dll is used by the DAQ VIs from the palette - are you by any reason calling the DLL directly from a Call Library Function Node?
Can you please explain what changes you made to the VI that caused the issue. It would also be a help if you submit the VIs that you are trying to build into an executable, thanks.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(3,109 Views)
