PXI
Glitch on ADC using FPGA module and different clocks
Hello !
I'm using PXIe and FPGA modules (5781 I/O modules + PXIE-7962R FlexRIO  and PXIE-1075 chassis) and I'm experiencing some problems related to the ADC...
I've reduced the problem to its simplest form (see attached screenshot) and when recording a DC signal and transferring it to server using FIFO, it appears that some digital glitchs occur (up to 1 every 10 microsecond)... see atached picture for an example...
The problem occurs when using all available FPGA clocks OTHER than IOModuleClock0/IOModuleClock 0 and 1.
However, for my "real" application, I need to decimate the clock (at 20 Mhz and below) and to use triggers, such that none of those clocks can be used (IOModuleClock0/IOModuleClock 0 does not support PXI triggers and IOModuleClock0/IOModuleClock 1 doesn't support clock decimation)...
So 3 solutions could be proposed :
-1. using onboard 40 MHz clock and avoid ADC glitches
-2. using IOModuleClock0/IOModuleClock 0 and enabling PXI triggers
-3. using IOModuleClock0/IOModuleClock 1 and enabling clock downsampling (decimation)
Unfortunately, none of those solutions are possible for now... Could you please help me ?
Here is my software configuration:
- Labview 2010 SP1
- FlexRIO 1.6.0
- Compact RIO 3.6
- FlexRIO Adapter Module Support 2.2.0 (has been updated as suggested here :http://forums.ni.com/t5/LabVIEW/fpga-IO-module-clock-with-TRIG/td-p/1750046)
Thanks in advance !
Best regards
Nicolas
(4,034 Views)
Hi Nicolas,
I noticed that you asked this question some time ago so I wanted to see if you were able to resolve the issue.  Do you still need assistance?
Brandon Treece
(3,860 Views)
Thanks for your answer...
We had some support from NI and it appears that the only way to ensure synchronisation betwen channels is to use IOModuleClock0/IOModuleClock 0... With the latest drivers, PXI Triggers are enabled... so this worked well for us !
THanks for the suport
Regards
Nicolas
(3,848 Views)
