PXI
Graphing data from a file on an PXI RT
I am using my PXI-8145 to collect 8 channels of data and store them as csv file on the CF card. This file becomes quite large (~100megs).  Occasionally, a user will access my local host app and needs to view a graph of the historical data (e.g. open the remote file on the PXI and plot one of the csv columns).  I can handle the graphing, but how would you go about accessing the remote file?  Forgive me if this is obvious, I am new to using the the RT module and sharing data.
Zach
(3,189 Views)
Zach,
       Have you looked into using a remote front panel hosted on your PXI?  Here is a link to get you started.  With your current setup, only one user can view the remote front panel at a time.  If you would like for multiple users to be able to view the remote front panel simultaneously, then you will need to purchase additional Real-Time Remote Front Panel Licenses.
Nathan
(3,174 Views)
