PXI
HS-DIO tutorials / guides / examples? PXIe-6544
Dear all,
Is there a repository for HS-DIO VI examples available? Are there tutorials? I am using a PXIe-6544 HS-RIO and would like to use static and dynamic signal generation. So far I got some basic functionality but often I am stuck. For the RIO or DAQ system there seems to be a lot more resources available. Also I could not find examples installed with the HS-DIO drivers on the local machine. What is a good starting point? Any help is appreciated. Thanks!
(5,011 Views)
(5,000 Views)
Accepted by topic author ideas-moose
Thanks for your patience. I talked to a friend from NI who pointed me to the right direction.
Examples can be found here:
Open -> Examples, and navigate to Hardware Input and Output -> Modular Instruments -> NI-HSDIO
Source:
http://zone.ni.com/reference/en-XX/help/370520K-01/hsdio/using_ni_hsdio_in_labview/
Hope this may help others in the future.
(5,000 Views)
Hi ideas-moose,
Sorry you had such a tough time finding examples. For future reference, when you open LabVIEW, you may navigate to Help » Find Examples, where you can find HSDIO examples for the 6544 or any other device at Hardware Input and Output » Modular Instruments » NI-HSDIO (High-Speed Digital I/O). Hope you find much success using the board!
Kyle A.
Chief Applications Engineer
(4,821 Views)
