PXI
Help with Error Msg
You'll have to forgive me, I am not a tech, just the operator. I have a an NI PXI 6551 Digial Data Generator/Analyzer
I have recently started receiving the following error msg and need help in resolving the issue. the error is:
ERROR - 1074115589 occurred at niHSDIO fetch waveform (1D U8).vi
Driver status: (Hex 0xBFFA4BFB) data requested has been overwritten in the device memory.
As i said I am an operator. The company who designed and installed the system no longer supports the system.
I need help in resolving the issue
Regards
Phil
(2,002 Views)
Hi Phil,
  • Has anything in the system changed recently? Like a software update or hardware change?
  • Can you test with a new cable? If the cable is old, it might be inducing so latency in the system causing a backup in data flow.
  • Can you send over a MAX Tech Report on the system? This will give us all of the driver versions you're working with to see if there was a bug or something. Instructions for a MAX Tech Report are in the link below.
  • Do you get this error on every run or just intermittently?
(1,965 Views)
Hey Captain
Considering this is a trainer located on a Naval Base can I call you Skipper?
Anyway...the problem just started about 2 weeks ago and it is consistent. I pulled the connecters and cleaned the contacts. when I initialize the system the card indicates it is "Active" and "Acessing" the information. I get to approximately 80Mb before the system crashes.
I am using the original software that came with the system. Ni Ver 5.0.0f1 I was debating on upgrading the system but I am not sure that would fix the problem.
I have attached the MAX tech report as requested. Again....I am just an operator. The techs walked away from this project about 2 years ago and I have been on my own so any help you can provide would be greatly appreciated.
Regards
Phil
(1,947 Views)
