PXI
High density matrix switch possibility
Dear all,
I am trying to put the matrix switch between 256ch analogue I/O.
pick 10 channels (the main problem is 10 channels are always change in every measurement.), and bypass 10 channels to another device.
I am reading PXI matrix switch brochures and manuals but have no idea which HW fits on the purpose, and the best configuration.
Any help will be really appreciated.
(1,512 Views)
Please provide a set of example scenarios to better understand your application.
How large the matrix has to be? do you need 256 analog channels to be multiplexed to how many devices?
Santhosh
Soliton Technologies
(1,483 Views)
@santo_13
Thanks.
Just single device.
I am trying to 'break' the 256 ch analogue connection between sensor and device. Connect selected 10 channels to another device, and those 10 would be any Ch. among 256 channels.
(1,478 Views)
By device you mean DUT, this can have any number of test pins of interest that you need to connect to the 256 AI instrument.
For example,
You could connect the 256 AI channels as columns of the Matrix, then connect all pins of a DUT as rows.
If your device has 4 pins, then you would need a 4x256 matrix to connect any of the 4 pins to any of the 256 AI channels. Now if you add another device, you need to add 4 more rows, now the requirement becomes 8x256 matrix and you can decide which channels connect to which pin of which device.
Could you please describe using a simple diagram of such sort depicting the device pins and how they are intended to be connected through the matrix with the AI channels?
Santhosh
(1,466 Views)
Given your requirements involves a massive number of channels, NI SwitchBlock would be the right option giving you high density.
https://www.ni.com/en-us/support/documentation/supplemental/10/ni-switchblock-hardware-architecture....
Santhosh
(1,463 Views)
