PXI
How can I generate Amplitude Modulated signal ?
I got this VI from the NI examples but in this VI "AM message signal .vi" is missing. So how can I generate missing VI or complete VI for the Amplitude Modulated signal using PXI 5441 and PXI 5610 as upconvertor. If possible guide me steps to generate.
Thanks and best regards
Vitthal Kodgirwar
Graduate Student
University of Texas at Arlington.
(5,968 Views)
Vitthal,
Thanks for posting on the NI forums. I am not sure why this example would be missing that sub-vi, but I will attach that sub-vi in my post so you can include it in your code. However, if you need to generate an AM signal with the 5441 and the 5610 it would be much easier to use the RFSG examples. These can be found in the Example finder under Hardware Input and Output >> Modular Instruments >> NI-RFSG >> Modulation Toolkit >> MT RFSG Generate AM.vi. This example will get you started with generating an AM signal with your hardware. Another note is that the combination of the PXI-5441 and the PXI-5610 is called the PXI-5671. I have included the links to a couple PDFs that should help you get started as well. Thanks!
NI RF SIgnal Generators Getting Started Guide:
https://www.ni.com/docs/en-US/bundle/signal-generators-getting-started/resource/signal-generators-ge...
NI PXI-5671 User Manual:
https://www.ni.com/docs/en-US/bundle/pxi-5671-features/page/overview.html
Aaron W.
CLA, CTA and CPI
(5,958 Views)
Accepted by topic author vitthal
Hi Aron,
How are you doing ?
 Thank you very much for your reply. Actually i found that VI in example problems but when I try to run that it showing some error
and the error is (niRFSG Initialize.vi<ERR>DAQmx Error -200220 occurred: Measurements: Device Identifier is invalid.)
The VI that I have attached is giving only a simulation results but I want to generate signal using hardware.
Please find the attached VI for AM generation, and guide me for the Error correction
And is the center frequency means carrier frequency?
thank you,
vitthal Kodgirwar
Graduate student
(5,942 Views)
Vitthal,
This error is occuring because you are not referencing the "Resouce Name" of your RF Hardware correctly. You should be able to look in Measurment and Automation Explorer and see what the 5610 device is named. This is the name that you should use for the "Resource Name" in the program. You will also need to make sure that you have the 5441 associated correctly with the 5610. These instructions are included in my previous linked "Getting Started..."guide. I have also linked the correct page here as well.
Yes, the Center Frequency is the same as the Carrier Frequency.
Aaron W.
CLA, CTA and CPI
(5,925 Views)
Hi Aaron,
Thank you very much for your help. Got the results.
thank you
Vitthal Kodgirwar
(5,919 Views)
tHANK YPU SO MUCH THIS ATTACHEMENT , THIS IS SLOVING MY ISSUE ,
THANK YOU SOMUCH SIR ....
(899 Views)
