PXI
How can I generate a arbitrary waveform with a Frequency List?
I want to generate a arbitrary waveform. The first part of my waveform must be a sine waveform of a high frequency (about 1 MHz) and the second part must be a constant signal of a low frecuency (as low as possible). Is it possible does a thing like this with a Frequency List).
My Arbitrary Function Generator  is NI PXI 5401.
(3,132 Views)
I think it should be possible because NI 5401 supports Frequency List Mode as 5411 and 5431 do. This is because they are DDS-based generators. However, NI 5412 doesn't support it.
I hope this clarify your question.
crisR
(3,119 Views)
