PXI
How can I get MAX to recognize the COMM and parralel ports?
I have a PXI-1000-B chassis with PXI-8156-B computer running Win98. MAX (Measurement Automation Explorer) will not recognize the COMM port or parralel port of the PXI-8156-B. What can I do to make it find the ports?
(5,585 Views)
You must install the latest VISA drivers to solve this problem. MAX 2.0 needs the NI-VISA driver in order to access the COM ports on your system. Without NI-VISA installed you will be unable to access or create serial, GPIB-VXI, or TCP/IP interfaces. Please check out the link below to download the latest NI-VISA drivers.
http://digital.ni.com/softlib.nsf/webbyproduct?openform&product=NI-VISA
Ryan Tamblin
(5,585 Views)
The latest NI-VISA has been installed, and MAX does recognize the GPIB port as well as the PXI cards installed. It is only the COM and parralel ports that are not recognized.
(5,585 Views)
