PXI
How can I implement simultaneous analog output from multiple boards?
I am using two PXI-6733 and one PXI-6289 boards.  The 6733 boards have 8 channels each of AO.  The 6289 has 4 channels of AO.  So in total I have 20 AO channels.  I would like to generate signals on all AO channels at the same time.  Can someone suggest a good way to do this?  Thanks.
(3,423 Views)
Hi epsilon-d...,
you can use three parallel loops. All wait on notifier. Each loop writes to one of your boards. If you want to send your data, then you simply send a notifier and all your boards will send the data.
Hope it helps.
Mike
(3,394 Views)
There’s an example on NI Example Finder which I believe will help you with your application.  The vi can be found by opening up LabVIEW and going to
Help>>Find Examples...  Once example finder is opened you can go to Hardware Input and Output>>DAQmx>>Synchronization>>Multi-Device>>Multi-Device
Synch-Analog Input-Cont Acquisition.vi.  You will need to change the analog input voltage channel to an analog output voltage.  You will also need to add a
second slave device, which mimics the first one, since you are using 3 devices.  All three of the devices can share the same reference clock and start
trigger, thus allowing them to be synchronized.  Please let me know if you have any further questions.
(3,388 Views)
