PXI
How can i change the offset of a signal which is generator through pxi??
How can I change the offset of a signal generated through the pxi system ??
(2,391 Views)
What PXI system?  What card are you trying to output your signal with?
(2,374 Views)
Ni-pxi 1031
(2,370 Views)
@tendoraj22 wrote:
Ni-pxi 1031
That is a PXI chassis.  What card are you putting in the chassis to generate whatever waveform you are trying to make?
(2,366 Views)
