PXI
How do I get a high data rate throughput from FPGA module to my PC running Labview app
I am using a 7811R (Ni FPGA board) and a MXI-4 card in a PXI-1031DC chassis. I am trying to measure the maximum rate I can send data from the MXI-4 card to my PC and up into a labview windows application. The PC also has a MXI-4 card which is on the PCI bus. My PC is a 3.2 GHz with 2 gigs of ram. When I run the experiment to dump data to my labview application, I get a maximum speed of 728KB/s. I think this is too low. Has anyone been able to get a higher through put and if so how did you do it?
Message 1 of 1
(2,915 Views)
