PXI
How do I install NiDaq on a Labview RT stand alone pxi?
I have a PXI 8196 that is running Labview RT. Unfortunately NiDaq has been deleted off of it. I can see it through max on my local PC. I would like to know if there is a way to either.
a: revert the hard drive back? ( This system is not partitioned with anything else)
b: install NiDaq using it as a remote PC.
Thank you
(3,507 Views)
Okay I think the best option for me is to re-format the PXI hard drive and then re-load everything from Max on the Host PC. Is this correct?
(3,504 Views)
Accepted by topic author griff32
YES u can reformat to do everything from scratch
followiing sequence ll help u
  • first install LV
  • install corressponding LVRT module
  • install "PXI platform services" from CD
  • install Daqmx
  • insert CD "LabVIEW real time target software" CD
  • go to MAX>>remote>>software>>add/remove>> install softwares to Target
(3,493 Views)
