PXI
How do I select the filter on PXI-5122 from NI-Scope or NI-DAQ?
The PXI-5122 has both an anti-aliasing and a noise filter.
How can I directly enable/disable a specific filter from NI-Scope or NI-DAQ? I see some input BW attributes, but I should think it's possible to directly select a filter?
I am using CVI 7.1.1.
Thanks in advance.
Message 1 of 8
(4,986 Views)
Hi Menchar,
You will need to use the niScope_ConfigureChanCharacteristics function and set the max sampling rate higher than 35 Mhz. The NI 5122 offers two filters that limit the bandwidth of the signal path a 20 MHz noise filter and a 35 MHz antialias filter. If you set the max sampling rate higher than 35 Mhz these filters will be disabled.
Hope this helps!
Brooks W.
Message 2 of 8
(4,970 Views)
Thanks Brooks, but I still don't have a good answer. I fully understand that there are two filters available, and that they are exclusive - both can't be simultaneously enabled.
What if I want to sample at, say, a 10 MSample/Sec rate (or a 5 MHz BW, take your pick) with one of the following conditions:
1. Noise filter only on
2. Anti-aliasing filter only on
3. Neither filter on.
These conditions overlap: simply specifying a sampling rate won't unambiguously select a filter. Simply specifying a channel bandwidth won't unambiguously select a filter condition either.
Message 3 of 8
(4,967 Views)
Hi Menchar,
There is no other way to "directly enable/disable a specific filter from NI-Scope or NI-DAQ". You will need to use the "niScope_ConfigureChanCharacteristics" function.
This means that if you don't call the function "niScope_ConfigureChanCharacteristics", you can expect the default behavior (filter on). Also, if you use the function above and send a "0" for the parameter "maxInputFrequency", you can expect the default behavior. For the 5122, you can expect the following behavior for different inputs to the "maxInputFrequency" parameter:
1to 20M = 20 MHz noise filter on
21M to 35M = 35 MHz anti-alias filter on
36M to 100M = Full bandwidth/no filters (100 MHz)
Best Regards,
Brooks W.
Message 4 of 8
(4,965 Views)
Hi Brooks -
So if I configure an input channel with the function you suggest to indicate a max input frequency of say 25 MHz, can I then select a sample rate arbitrarily low (say 1 MS/sec) and still be certain that the antialias filter didn't get turned off and the noise filter turned on? That is, does the max input frequency parameter exclusively govern filter selection?
Message 5 of 8
(4,962 Views)
Hi Menchar,
Yes, the max input frequency parameter does exclusively govern channel bandwidth (and indirectly filter selection). Yes, the anti-alias filter will be on at 25Mhz and you can specify a low "minimum sample rate" (say 1 Mhz). You have got the right idea...
Best Regards,
Brooks W.
Message 6 of 8
(4,958 Views)
The spec sheet states the anti-aliasing filter as the default filter. How can I assure that  for sampling rates below 20 MHz, the noise filter is on and not the anti-aliasing filter? I really need the noise filter to be on.
Message 7 of 8
(4,799 Views)
Hi Westlinwind,
You will need to use the "niScope_ConfigureChanCharacteristics" function or niScope Configure Chan Characteristics.vi.
Set the "maxInputFrequency" to something between 1 to 20 Mhz.  This will enable the noise filter.
Best Regards,
Brooks W.
Message 8 of 8
(4,791 Views)
